Nearly 35 years experience and customer care, printing since 1992
all our plastic cards are proudly printed in England Proudly printed in England all our plastic cards are proudly printed in England
Tel 01948 664 806 Email: sales@cpcards.co.uk We aim to reply within 10 minutes 9-5 Mon-Fri
CMYK vs RGB — Why It Matters for Plastic Card Printing
RGB is for screens. CMYK is for print. If you send RGB artwork to a card printer and nobody catches it, the colours that come back on your finished cards will be wrong — sometimes dramatically so.
That vivid neon blue on your monitor? It almost certainly cannot be reproduced in CMYK ink. You will get a duller, different shade. The sooner you convert your file to CMYK and proof it, the fewer surprises you get.
View our plastic card printing options
What RGB actually is
RGB stands for Red, Green, Blue. It is an additive colour model — screens mix light to create colours, and combining all three at full intensity gives you white. It has a much wider colour gamut than print, meaning it can represent colours that physically cannot be reproduced with ink on a substrate.
What CMYK actually is
CMYK stands for Cyan, Magenta, Yellow, Key (Black). It is a subtractive model — ink absorbs light rather than emitting it. Mixing all four inks produces a dark brown-black in theory; that is why a separate black (K) ink exists for clean, dense text and solid dark areas.
Plastic card printers — whether offset litho or digital — print in CMYK. Your artwork needs to be in this mode before it goes on press.
What goes wrong with RGB files
  • Colours shift on output, especially saturated blues, greens, and oranges
  • The RIP (raster image processor) at the printer converts RGB to CMYK automatically — but it makes its own decisions about how to do that, not yours
  • Brand colours can drift significantly. A Pantone-matched corporate blue can look purple or grey
  • Some printers will flag the issue; others will just print it. Do not rely on them catching it
How to convert correctly
Adobe Illustrator or InDesign: go to Edit > Colour Settings, set your working CMYK profile (usually ISO Coated v2 or FOGRA39 for European print), then convert your document colour mode to CMYK.
Photoshop: Image > Mode > CMYK Colour. Do this before you start laying out artwork, not at the end — converting after the fact changes how every colour looks on screen.
Canva and similar browser tools: most do not give you true CMYK control. Export as a high-resolution PDF and check with your printer whether their workflow handles the conversion, or use a proper design tool.
Spot colours and Pantone
If brand colour accuracy is critical — a specific Pantone blue, an exact red — ask your card printer whether they can match Pantone references. Many digital card printers cannot; they print CMYK only. Offset litho printers can often add a spot colour at extra cost.
If you specify a Pantone colour, make sure your artwork uses the correct Pantone swatch, not just something that looks right on screen.
Ready to send your artwork?
Always supply artwork as a CMYK PDF with bleed. If you are unsure, ask your printer before you finalise the design — not after you have ordered 500 cards. We are happy to check your files before you commit.
View our plastic card printing options or contact us if you have a question about your artwork.
Not sure what you need? Ask us
